Hi im new here.
I recently purchased an IH 574 and im not familiar with it yet so i would be glad of some assistance from others.
Two main problems that i have noticed with my IH since i started using it for some work recently. It hasn't had a great deal of use recently so i'm starting to uncover some issues now:
1) I park it up and leave it running at around 2000rpm so i can use my log splitter on the rear. Once the tractor warms up, there is a loud chatter from the clutch / transmission. It sounds like metal on metal so i was concerned. On closer inspection, i found that the noise dissapeard if i depressed the clutch or even just slightly pressed it down to the biting point. The PTO wasn't running and the tractor was stationary so i'm a bit confused. I have also topped up the transmission oil so this can't be the problem. Could some adjustment to the clutch be needed?
2) The first time i ran the machine hot, the exhaust started leaking oily residue onto the bonnet. I initially thought that this was just the tractor needing to run hot for a few hours, however this has continued to the point that it runs down the side of the engine and drips into the floor. In addition to this, the radiator seems to be losing water with no aparent leaks. I used the machine for 2 hours on saturday and found that the radiator needed around 1.5 litres of water after it had cooled down. The engine oil level does not appear to be going down either. Could this mean that a new head gasket is required? (hopefully not!)
Thanks in advance!
This post was edited by RW-IH574 on 12/12/2022 at 04:57 am.
Thanks in advance!
