Transmission Flushing Agent
djcarney
I recently bought a 520 and find that the transmission fluid needs to be changed. It appears to be contaminated with water and is milky in color. The manual calls for 3 gallons of a "flushing agent" to be used after draining but does not give a hint what to use as a flushing agent. I have read that diesel fuel can be used. Is this a good choice? What are members using?
Advise driving a stalk in the ground and running a strong rope to the top of the clutch handle just in case. Or, you can sit on it so you can pull the clutch if it takes off!
