Transmission/Hydraulic fluid
Rkh
Anybody use Wal-Mart's brand of Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid?
This is all we run in all our Tractors mostly Case powershift tractors. No complaints. Though it is quite thick in winter (-35C) so then we add a partial pail of synthetic Hytran into the tractor.
Ranch.
It depends on what sort of transmission and hydraulics your tractor has, where you live and most important of all how often and for how long you use it. UTF will absorb only 1% moisture, and then it turns into a coffee milk shake loaded with moisture and ruining your bearings.
(quoted from post at 20:10:06 09/30/21) How does All this water get in ?
SV, it is condensation. Here in the Northeast as in some other parts of the country we get a lot more than in the Southwest and in your area. Tractors that are in regular use will generate enough heat to frequently drive it off. Older tractors that mostly sit, accumulate more and more.
