Transmission I.D., 460 Utility
dwragon
Could someone tell me how to identify the transmission on a 460 Utility. Tractordata shows three different transmissions. All I know about it is that it has a clutch pedal and a shift lever in the center of the case. I dont want to try and pull the 460 to the shop with it having any type of hydraulic transmission.
460 should have a all manual gear transmission, reverser with TA and with out. All mechanical. Different variations but no Hydro. Should have a short lever in the middle for main gears and maybe a
lever on the side in one of two places.
When you say pull it does that mean under its own
power or towing it with another means. If towing it a
couple hundred feet or so there is nothing in that
tractor that can be damaged in that way.
(quoted from post at 09:05:05 04/09/22) When you say pull it does that mean under its own
Might need to tow it about 600 feet.
