hotdawg1984
Ok. Got engine rebuilt in my 8N and had to pull motor to replace clutch and pressure plate along with the pilot bearing.
Happened to check the input shaft and found it had a lot of play both in and out (about 1/4" + or -) as well as up and down.
Never done one of these before so
my question is ,,, how much in and out play should there be? is 1/4" too much?
I believe the up and down play is a direct result of the amount of the in and out play.
I did pull the shaft out , cause it was easy to do, and while the bearing looks good as well as the race, the bearing seems loose on the part that is pressed on the shaft. If I shake it iwill rattle?? is that normal??
Thanks all.
Thanks all.
