Transmission Specs
dukekars
Hi, I am doing a complete frame up on a 1953 MH Mustang, model #23. My question on the front side of the transmission just left of main output shaft, there is a cap with a bolt 1 7/16 nut with cotter pin. I believe its the counter shaft. Any one know the torque spec on this bolt? As well torque spec on the 2 1/8 main nut on the output shaft. I have the IT manual but it says nothing about a bearing preload or torque spec. on either of these?
Yes it has two sets of holes, one holds the nut..thrust washer just in contact with the bearing, to go to the next hole would be about 40lbs plus of torque which to me is way to tight to preload that bearing. Limited choices.
