transmission swap
farmer656
Can a 5 speed trans out of a 861 fit on a 900 with the 4 speed in it, I can buy a clean 900 , but it has the 4 speed, I have a parts 861
Depending on the S/N of the 861 it will either be a direct fit or the output shaft couplers from both tractors will have to be cut in two and half of one welded to half of the other.
In addition to what Larry said you will also have to change out the clutch and you with have no left brake.
