transmission
Todd R
Is there a transmission dip stick some place other than under the cab next to the fuel tank and is it possible to bleed the hydraulic system I replaced the line under the seat which I believe lifts the seat but I dont see much fluid if any going threw the line when I raise and lower the seat thank you for your help also when running I look at the hydraulic filler access hole the fluid seems to be rolling is this normal
