tricycle front axle
rray
These questions are for my 67 Farmall rowcrop 504 with tricycle frontend. The lower bolster 380660R91 has a slight tilt. Should it be mount with the tilt forward or backward? When I took it off it was mounted forward. The axle has what is described as a dust deflector43462D. Is it mount with the cup on the top or bottom? The ones I have seen were mounted on the bottom. The parts manual shows it on top. These may seem to be silly questions but there are none of the old tractor folks left in my area who know what a rowcrop tractor is.
Wheels should be attached so they are farther toward the rear. This causes caster. Caster helps keep it going straight,
Reversing it will cause problems keeping it going straight. I think the dust shield is placed so it does not catch water. Jim
