Trouble starting my 4600
captjack
I used the tractor all day parked it and the next day it would not start. It always is very easy starting. There is fuel to the pump. It seems not to be getting fuel to the cylinders. Would an injector pump just go out?
I am hoping for a less expensive solution.
make sure the kill cable is pushing the lever all the way forward into the run position..
if no go, then check for free fuel flow up to the inj pump.
Thanks for your reply They were the first things I did check. It just seems strange that it will not run. I am having a hard time thinking it is the injector pump.
When you open the pump bleeder and crank the engine does it shoot fuel out the bleeder as far as the front wheel? If it doesn't come close to that, start tracing backwards to the tank, filters, lines, etc.
If it does shoot good fuel, then open all three injectors and see how much it's putting up with the throttle at MAX.
If it's spitting a bunch of fuel and air bubbles but won't seem to start then I would expect that there is a leak somewhere before the pump that is drawing a small amount of air.
If there's nothing coming out the injector lines, and I mean bone dry... then I expect a problem with the metering valve in the pump.
You could probably remove the top cover of the pump and very carefully note the position of all linkages and springs... then pull the metering valve up and clean it. Should just be some rust/water type of crap. If there's other metal or plastic bits in there then might be a govenor problem. Then you get pump rebuilt... but if it's just rust, clean and reinstall.
Some do this with the pump on the tractor. I prefer to remove the pump myself...
Rod
