truck cap window lifts
beetgrower
I don't know where else to go with this; I have a 20 year old A.R.E. pickup topper with non-functioning window lifts. Are these off-the-shelf items I can get at an auto supply store? Are they hard to install?
There should be a series of numbers printed on the shocks, often a hyphenated sequence like ABC-12345. Take those numbers, or a photo of the numbers, or one of the shocks, to a parts place, and they should have a match in stock unless it's an odball. If you use those same numbers, you can usually find them on online retailers for half or less of what a parts place charges.
Most of them now have ball studs with a c-clip-type keeper; you use a pick or small screwdriver to pull the clip back from the ball head, then just pull the head off the stud. But you may have one with a through-bolt or some other arrangement, you'll just have to look. None of them are hard, just be sure to prop the lid up securely before you remove them. ;)
Good luck!
Struts were bad on the last truck cap I had.
I raised the hatch and propped it well, drilled a 1/8" hole through each rod near the cylinder to insert cotter pins. Drilled 1/8" holes in side of stake pocket on both sides of truck to store pins when hatch was down.
Cheap hillbilly fix that worked well for several years.
You might take one of the old ones off to find out what is involved.
