Truck live hydraulics
dieseldoc
Anyone know were I can find a coupler to go on crankshaft dampner and a shaft to run hydraulic pump? The engine is a 93 N14 cummins.Thanks
where i live we go to drivetrain inc.you should be able to get one from any driveline builder in your area
or froma dairy feed mixer maker in your area
It may not be that simple.
I ordered my new 1980 S-1954 IH truck with the provisions for front mounted PTO. It included frame extensions, special bumper, special radiator with hole for drive shaft, drilled harmonic balancer, and special hood.
When I received the truck, I had to buy the flanged u-joint, driveshaft components, Chelsea gearbox, and flex coupling for my pump. The pump was a 45 hp high pressure water pump.
Is there a reason for not going with the hyd pump that mounts on the left side of the engine, near the accessory drive?
I need 40 gpm oil supply. I am building another manure truck.the last one I did I found parts at a junkyard but no luck this time.
