Greetings, I have a Spicer 5 speed from an IH single axle truck with aluminum case that lost the input shaft gear and countershaft gear (all started with bad tooth). Tearing everything down I noticed that the main shaft and countershaft bearings and races just fit snug in the case, not a press fit. No evidence that the bearings spun in the case. It seems that the pre-load from the shaft end caps keeps everything snug but I could still pull them all out by hand. Is this normal? I'm not that experienced when it comes to transmissions. If it is normal should I use locktite bearing retainer when I go back together with it? Thanks!!
