Truth from a 6 year old
David G
We had the little guy today.
I asked him what the most important thing in farming is, he replied "don't get your biggest tractor stuck".
They do listen.
I violated the little guy's rule (both stuck), but not to worry, I borrowed an even bigger tractor. :)
We've all been there "Sure I can make one more round a little closer". That's why they make long chains and good neighbors.
Does that include dozier?? Back when I still had TD6 I got it stuck and my Diamond-T and an Oliver 77 could not get it out and that was with both of them pulling on it
I did not get stuck.
I was just giving him a spot quiz.
He is pretty good, knows to drive with bucket as low as possible, don't use 4WD until you need it, and don't get big tractor stuck.
There's a similar rule for four-wheelers: Keep it in two wheel drive until you get stuck, then put it into four wheel drive and go home.
Some times is better to flip on the 4x4 before its to late. Today I ran the combine 4x4 just because its greasy and I will not track up the field near as bad
