TSC oil on clearance.
mmidlam
The black jugs of CI rated oil are on clearance at $14.99 for 2.5 gallons. Its being replaced by CJ in white containers. I am thinking about buying all of it. its claimed the CJ has more zddp but the CI has a higher rated base stock.
Thanks for the heads up M.
I've been wanting to let you know I went through the zareba lighting arrester and the zareba ali-100 mile fencer. But the pics I took came out kinda fuzzy so need to retake them. Identified most of the fencer parts except for the diacs and such that are too small. When I get the pics taken again, I'll first post the contents of the lightning arrester which is basicaly 5 big MOV's in series with a big resistor shunted across the terminals. Since the fencer works, I thought I'd run the voltages across all the caps and scrs (4 of them) before I post that.
