tube repair
Sparks
I had a rear flat on my 8n.
Found out that the valve stem had separated from the tube. Not sure if this was THE problem or what happened after the tire when flat and I didn"t notice it. I didn"t see any other obvious holes in the tube and of course couldn"t pump it to check for leaks.
I was talking to an old guy (WWII vet old) and he said that I could vulcanize a new valve stem back onto the tube. Fix it instead of throw it out.
Is that something that a normal tractor dealership/repair shop could fix?
The other question is about tubes. What is a good price for rears? I saw two for $45. Is that a good deal?
Any internet sources I should check into for a good deal?
Thanks.
Any tire shop that deals with ag tires commonly does that.
As to whether putting that money into an old tube is worth it. take a good look at the overall condition of the tube, then decide.
sparks, when i bought my rear tires and tubes i ended up with a x-tra tube, thought about saving for a good snow. could be years though before that happens here. it can be yours for the shipping cost. and a big mac
I save old tubes to cut them up for gaskets and such. i always save the valve stem and about 4" of rubber around it, as long as the stem is good. I have cleaned up the rubber and then scuffed it with a tool for a bike tube, then cut an old seperated stem out and cleand and scuffed it's rubber, and then used rubber cement to glue it up.. has always worked fine. i do that on tubes that otherwise still hold air.. but aren't worth putting money into.
soundguy
