Provided the boost pressure is set low, probably nothing. If boost pressure is too great, the bottom end will fail in time, either from fatigue on the conrod or main journals, or rod damage.
Remember, if you try to extract extra power from an engine that was not originally designed to accept a turbo, it will usually come at some sort of a cost.
What sort of engine are you looking at?
i think it is a 354 6 clynder but not shure i have to ceck on the seal number it is in a army truck right now i want to put it into a 1 ton pickup if you use one out of a comebine you have to change the front pulley they are not set up for up and down the the gas in the combine they run one speed all the time thanks
