John Quillen
I have a John Deere 4200 HST with a JoDale Perry Cab.
Problem: To start with I had to replace an in-line fuse that blew due to an overload of the circuit. The Flasher does not work at all, so I assume that the Flasher needs to be replaced. Don't know where the Flasher is located?
When I push the turn signal up for a Right turn the arrow on the dash lights up for a Left turn. (Left light comes on) When I pull the turn lever down for a Left turn the Arrow on the dash lights up for a Right turn (Right light come on).
I haven't changed any wiring so...???? Would those Relays located in the Fuse Box have anything to do with the problem? And if so, how do you check them to see if they are okay?
One thing for sure, I know where to turn when I have a problem and I sincerely appreciate your help.
John Quillen
John Quillen
