I bought a TW-35 last year to run a 3x4 baler, had issues with the PTO slipping, had a shop work on it. They dyno’d the tractor when they were done and it would only pull 140 PTO HP, as far as I can read they are rated at 170. The baler calls for minimum of 145hp. The PTO wasn’t slipping it was pulling the engine down, it was starting to smoke so I don’t think it’s fuel related but most likely air. I found the exhaust manifold has a small crack, not sure if that’s enough lose 30hp. Is there any turbo upgrades you guys would recommend? Is the aftercooler something that leaks often? Would like to get more air to it first before twisting any fuel to it.
