TW-35 steering issues
scmi
we got this tractor last spring from a auction for a great price because bit had a bad rod bearing .i put a reman in it and i replaced the steering pump because the mount tabs where broke on it. and replaced the hand pump motor on the steering shaft because it was leaking. now it will work for awhile then it loose power assist when it is not working there is no pressure on the pump output i had the pump apart and didn't see anything that i would think might cause this it is a front assist tractor
