TW35 Dual power shift problem
I have a 1983 tw 35. When tractor is cold the dp shifts good. After about an hour of use, if I shift from hi to low it sticks in low and will not shift back to high. If i do not shift to low it will stay in high all day. I have check the power going into tran. I have power there when the green hi light is on. The lights change fine its not in the swithch. Any ideas what it might be. Don"t like my local dealers idea split tractor then guess whats wrong. Thanks Glenn
It sounds as if the solenoid is going south. Either the coil is weak when hot, or the valve itself is sticking. The complete assembly can be changed without splitting the tractor. Not cheap, but if it functions in whatever mode it stays in, that's my thought.
I would also do a pressure check of the low pressure hydraulic system. There should be a 1/8 NPT port on the side of the hydraulic pump cover. Put a 500 PSI gauge in there and check the pressure when at operating temp. You should have at least 130 PSI there when hot. You have to check with the DP in high and low and with the PTO on and off also with the diff lock on and off and when depressing each brake petal. All these will affect the low pressure system if there is a leak.
We split our 9000 in a few hours but the 9000 has 1/10 the electrical crap that the TW35 has.
Good luck
Jason
Agree with Rick. The solenoid is easy to get to on the RH side of the trans. If it were mine, I'd remove, disassemble, clean, and re-try. You don't have much to lose.
I have not had a chance to test the press with a gage yet. The low press light dose not come on when tractor is running. The brakes and pto seam to make no diff on the dp when the selenod sticks. I was thinking that it was a chance that it was just a weak coil or somthing in the valve. What do you have to open up to get to the the selenod. I can find where the lead wire goes into the back of the bellhousing. I can see were the oil line from the pump goes into the tran. Having trouble seeing the selenod valve.
Thanks for taking the time to give my problem a look. Thanks again.
Follow the wire straight down into the trans. On the side of the trans, you'll see a steel plate with two bolts in it. Loosen these bolts and slide the plate out. There will also be two hydraulic lines that you'll have to remove first before removing the plate.
i had the same problem with my old 35, the hyd supply line to the dual power had a little inline screen. that was plugged up with metal shavings. check that little screen before you start buying parts. (my brakes were shot, filings were a huge headache)
