pyobluebonus
I have u4 power unit engion over axel. I'm a need of a clutch or someone to resurface it it's different than an H clutch the hub or center piece is 1.50 in diameter.
Hello ..blue.. welcome to YT. Is whatever machine this is on utilize tracks or use crawler type two lever steering? If not I would almost say the transmission and final drive section on the machine was not produced by IH. I am ONLY basing this on the fact that I have a older IH published repair manual for the Farmall M, W6, O6, U6, T6 etc. It makes no mention of a over the axle engine transmission and final drive other than for a crawler or dozer that incorporates steering clutches. So knowing that I would be surprised if they built such a thing for the Farmall H, W4, U4, T4 etc. series and not for the larger series equipment utilizing the engine for the Farmall M. I suppose if you find IH casting marks on it I will have been proven wrong. I have seen in the past posts here that people have listed places to send clutches to get them relined. Maybe someone will chime in with some info on that.
I have several IH publications specifically on the H and 4-series engines, tractors, and other things. IH certainly did make an IU-4 engine mounted over the top of the rearend from an H or I-4 industrial tractor for use as a power unit for mobile equipment like road graders, maybe paving machines, The engine faced backwards driving off the output shaft from the clutch then down to the top input shaft of the transmission. The engine sitting on top of the transmission and final drive made for a very compact power unit. It's a very limited production item, hard to track down info on.
Okay Dr. I stand corrected. I am surprised the IH manual I have does not mention that setup, it sure seems to cover all other aspects of the M - 6 series. Since it is low production it could just be that it has its own specific repair publication. This post is not that old, but what is more interesting to me sometimes these guys get zero replies for a day or two even more. But when I chime in and give some off information that I usually base on some type of documentation, then posters come out of the wood work giving their best shot of supplying every correct detail. Just an interesting observation from my end.
According to the Service Manual GSS-5032 Farmal-H and 4 Series Tractors and Power Units, the IU-4 clutch is either the same spring loaded clutch as used on the Farmall H or W-4 tractors or an over-centre clutch as used on the I-4 tractor.
I only have a parts manual for the 1u-6 but I do have a owner's manual for the IU-4 . it says it has a 10 inch clutch but no part number. H or W4 use 10 inch clutch. maybe you could use those clutch linings
(quoted from post at 17:57:35 06/11/22) According to the Service Manual GSS-5032 Farmal-H and 4 Series Tractors and Power Units, the IU-4 clutch is either the same spring loaded clutch as used on the Farmall H or W-4 tractors or an over-centre clutch as used on the I-4 tractor.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto128015.jpg>
I never seen an i4 with an over center clutch. I currently own 2 of them and had a few others. orchard tractors all use over center clutches
