I recently acquired a Massey M135 with an M300 loader. Problem is there is also a backhoe that I can find no tag for in any of the recommended search areas. It's just gone.
Can anyone identify this implement or get me close to a year and/or model so I can order a manual for the parts needed below?
Problem #2 is the main cylinder is now spitting and has to be repaired. Luckily both pins come out easily. The problem is the cylinder on the bucket end will not turn loose. There is an access hole in the frame underneath that I assume is for greasing the pin because it is slap full of old grease, et al. Therefore I can not see if something else needs to be disconnected before removal. Can someone tell me the correct way to remove the cylinder? I considered putting the pin back in the tractor end and using the hydraulics to pull it loose, put I do not want to damage anything. And once it is loose, I fear it will not come out of its location. Should the boom be up or left/right for removal? Thanks for any advice anyone is willing to give.
It is giving me a fit with the pics.
I apologize. It's not letting me upload any photos but I'm still trying. But if anyone could comment on the removal I'd appreciate it.
This post was edited by Duhhuh on 08/15/2021 at 05:59 pm.
