Unloaded equipment
SVcummins
Finally got equipment unloaded from the drilling job over a month ago.
Also wondering how would I go about cleaning an old fuel tank?
If it is a steel tank and had diesel or gasoline, or even propane, you will not be able to put potible water in it without nasty taste getting through to your buds. Yuck. But clean enough to use for watering or a pressure washer supply. just use a half cup of Dawn or Palmolive dish detergent. and 1/4 full of Warm water, and drive around where it is not real flat. Jim
Look for rust. If not bad, run it after it is dry. If it sis rusty scale, treat it like a mounted tractor tank, and maybe roll it around with nuts and bolts in it, then coat the inside. Jim
