ohiojda
Im working on a 1937 A and I cant locate the mark on the cam gear to line up the governor gear. the mark to line up to the crank gear is there, can anyone tell me how to find the right tooth? maybe count teeth from the mark for the crank gear? thanks.
Roll the crank till the left cylinder is all the way to the front on compression stroke,roll the gov.shaft till it is flat____or level with the case and set the gov. on the cam gear making sure the gov. shaft stays level with the case.gov. will be in time if you have the cam gear right.
flat
