Unstyled JD A cutaway
OK here's one I need some help with. I am not a math person nor am I an engineer person so I am not good at this which is why I am reaching out. I purchased a homemade Unstyled JD A cutaway that the previous owner designed to run off the PTO of another tractor backed up to it. It is really very well done but I want to convert it to drive with an electric 110/120v motor for a number of reasons the first being eliminate the noise of the 2nd running tractor and more control. Currently it is set up where the drive tractor pto shaft drives a large sprocket with a chain driving a smaller sprocket mounted on the PTO of the cutaway. I don't mind hooking the electric motor up directly to the large sprocket instead of directly on the PTO sprocket but I don't know anything about how much torque I'd need etc. I looked up engine speed of a running tractor and its 975 that would put the PTO at 540 normally. I have seen this cutaway running before and the engine did turn slowly with the drive tractor running at what I'd call pto speed. Does anybody have any suggestions on where to purchase and what size, type motor I could get and hook up directly to the PTO and get the speed down to where the motor on the unstyled JD A cutaway turns very slowly so folks can watch the pistons, valves etc move slowly. I think this will be very cool to take to the shows and even some of our school ag mech classes but I think the electric motor with a simple on off switch would be a lot safer. Thanks in advance for the help and I look forward to see what suggestions the community comes up with.
most electric motors run at 1725 rpm or 3450 rpm then calculate from there the size sprockets you will need to attain thew right speed small drive sprocket with big driven sprocket will slow down your speed ( think drill press) then figure out what speed your cut away will turn and go from there unstyled A was gear driven pto so should correlate to engine rpm hope this helps fossil
It would be interesting to have a crank on it (other than the flywheel), so a person could turn it very slowly. That way you could easily stop it at TDC and BDC.
I’d like to see a photo of it.
Once you get it all set up, lubed up, turning free, put a torque wrench on the PTO, turn it, see what it takes to turn it through at the tightest spot (probably when a valve is opening), multiply that number by 125%.
Record that number, determine what RPM you want it to run, find a gear reduction motor with that RPM output and torque capability.
Gear reducer motors that size are expensive. Look on Ebay, other sources for something used or surplus.
I think I would look real hard at using an electric over hydraulic power unit an all in one unit.
Or cobble up your own with electric motor, tank, valve(s) and hydraulic motor on the cut away pto.
With the right controls output speed can be variable via the operating valve.
No chains, sprockets, gears, shafts, bearings etc.
You need to work backwards to figure out the gear reduction that you want/need. Figure out what RPM you want the engine to turn at. For arguments sake let's say that is 30 RPM, or full stroke of the piston in one direction in one second. You can lookup what the engine RPM of the A is when at PTO speed. That will give you the gear ratio through everything in the tractor itself. I'm going to say it's roughly 2 to 1 to keep the discussion moving. So the pto will turn at 15rpm when the engine is at 30 RPM. If you use a 1750 RPM electric motor you will need rough a reduction of 116:1 to get to your desired pto speed.
You probably can shop around and find something close enough.
Oh and I am an engineer and own an original 720/730 cutaway tractor. I would be glad to help you figure out this as best as possible.
Thanks to all so far for advising. I'll try to add pictures tomorrow. Hotrodtractor as I said I am not an engineer so I appreciate yours and everyone else's help and I'd like to see pics and know how your 720 cutaway works and is set up. I am trying to get the simplest yet safest way to drive this thing and an electric motor seemed to me to be the best way. I'll take some pictures this evening or tomorrow depending upon what time I get home from work and send them. I can also measure the sprockets that are there etc if that will help you guys help me. There is a lot I want to add back on this tractor too. Right now it doesn't have a fanshaft or radiator hood etc and my hope is to get it looking more like a complete tractor eventually but I have to get the drive issue resolved first.
Find a gear box for a forage wagon or manure spreader apron chain and hook your motor to it .that should slow down the motor quite a bit
Honestly a video of it running would allow us to estimate its current RPM. If you want it the same speed, faster, slower, whatever it would give us a target to help make it exactly what you want. (we can measure the speed based on the video)
On the original cutaway display tractors there was an electric motor. On the 720/730 it was mounted down below where the starter should have been and drove the flywheel. My tractor is missing many parts including the motor, but I will get some pictures of this specific area. I also have other pictures at home that show exactly what it should have been.
Just an idea. Could you get enough speed reduction by mounting the electric motor under the tractor and running a long v-belt around the flywheel? Perhaps that would require a second reduction to turn motor as slow as desired?
IF the pto was turnig at 540 and then geared down just count the teeth on both sprockets. That will give you the reduction from PTO speed then just use the ratio of about a third slower gearing for an electric motor. Another words if your current sprockets are 30driven and 10 driver you are at 3 to 1 or reduced by 2/3 so now you would need to either put a jack shaft in for another 3 to 1 or just use about a 60 to the 10. You could have somebody turn it by hand to see how fast you want it then use that speed to figure the drive speed.
Ok here is some more info and pictures. It had been a while since I looked at it but I had mentioned it was designed to drive off the pto of a running tractor backed up to it. I took pics yesterday. the pto shaft of the running tractor is turning a small sprocket that I cant find any markings on that by chain is turning a large sprocket on the cutaway pto shaft. I was able to pull up data on the large sprocket. It is a Martin 60BS54 1-1/4Chain number 60 number of teeth 54 outside diameter is 13.327
Sorry but I cant figure out how to rotate the pictures so these are sideways. You will have to tilt your head to the left to see them correctly lol
If this tractor was electric start I agree I think hooking up an electric motor would have been easier because you would be able to adapt into the starter area. I posted some pictures so you can see what I have to start with. I don't think this is really going to be that hard to figure for somebody with that type skill set. It's just outside my level of expertise. I can hook it all up directly to what is there but I have no idea what size etc electric motor I'll need to have enough power and the right speed to drive it.
That's a great idea, that will certainly drawn a big crowd.
Full speed will make everything that moves look like a blur, much like trying to watch a radiator fan spin. Running slower will make it much easier to see and to comprehend. Something like 2 or 3 seconds for the piston to move from top to bottom would be around 12 RPM at the crankshaft and 6 rpm at the PTO. Would driving it all with a flat belt around the flywheel be easier to setup? Maybe a variable speed DC motor drive would let you fine tune the speed without having to replace any parts?
Please include some form or glass or Lexan covers over any moving parts, especially the pinch points. People really enjoy moving cutaways, but will often start pointing and sticking their fingers in places while trying to figure out how it all works together.
Again, that's a really great idea, please tell us where and when it will be on display, I'd like to see it too!!!!!
That is exactly the way he described it set up to do. No bention of a reversing setup on PTO to PTO. And 1 second per piston stroke is way to fast.5 seconds per piston stroke would still be too fast.
