Unstyled JD B radiator
I'm in the process of restoring a 1936 John Deere B and can't get the radiator to seal up. The gasket surface of the top tank has been corroded away, almost flush with the bolt holes so that there little to no contact between the tank and the gasket. Can I build up the tank and then machine it down to make a better gasket surface? Or where would be a good place to find a replacement tank?
(quoted from post at 21:57:26 07/05/11) I'm in the process of restoring a 1936 John Deere B and can't get the radiator to seal up. The gasket surface of the top tank has been corroded away, almost flush with the bolt holes so that there little to no contact between the tank and the gasket. Can I build up the tank and then machine it down to make a better gasket surface? Or where would be a good place to find a replacement tank?
This is a common problem on these cast radiator parts. Yes, you can build them up and this is what most people do using JB Weld or etc. I usually just hand file mine down level enough to seal up. There is no pressure on these systems so it doesn't take much to seal them.
