jd2cyl1943
Location
Bemidji, MN
I got the tractor jacked up to get the tires off. I'm bit behind schedule.....
Found some nice JD Green under old grease.
I gave the front end of the tractor a good washing.
I sprayed out the radiator fins to clean out the dust. They look pretty good. I'll be reusing the original 80yr radiator.
Before removing the tires, chain, or heavy ratchet strap the axle housings to that 4X4. The final drive housing is too narrow to balance well. The width of 4X4 and stand position is good. Jim
that 4x4 looke like a chicken fixing to me. But if it will hold one tire at a time it should be fine change the tires right on the machine. One tire will keep it balanced to the oppsite side while working. I would block under the axle housing if it was me.
