update 2755 hydraulic problem
gfj
did not start tractor sat and sun went out and started it this morning. everything is working like it was before. will wait and see if it keeps working. thanks for all the advice will keep the replies if it happens again
(quoted from post at 19:53:47 03/30/20) did not start tractor sat and sun went out and started it this morning. everything is working like it was before. will wait and see if it keeps working. thanks for all the advice will keep the replies if it happens again
I would assume that you removed, cleaned and inspected the transmission oil screen ? And removed/replaced the transmission oil filter ?
How are the loader hydraulics plumbed into the tractor ?
when was the last time the coolant radiator and oil cooler were flushed clean with a low pressure water hose , to avoid bending the fins .
Forgot to add. Any difference when the transmission dash rabbit/turtle is in either position ?Any difference if the pto is engage or not ?
used the tractor for about 5 hours today everything worked perfect. did change filter and screen. expect this will happen again hope I will be the one using tractor
