Update. Did I luck out???
Goose
A couple of days ago, I posted a thread about an oil leak by the oil filter on a 24hp Briggs & Stratton engine.
From other postings, and research on the Internet, I became aware that the 24hp has/had a problem with the crankcase gasket leaking on the left side of the engine near the oil filter.
I power washed the engine, then removed the oil filter and sprayed the area down with spray carb cleaner. Installed a new filter and topped off the oil. I ran it in the shop for 20 minutes and had no sign of a leak. Mowed with it for a half hour this afternoon.
No sign of a leak--yet, The gasket on the old filter did come loose from the filter when I removed it.
I'll run it some more tomorrow.
If it turns out to be the gasket I do not put a gasket back I use good automotive RTV to seal them... BTW its not a bad job to do it can be done in a few hours : )....
Why the gasket slips they did not use enoufh bolts to clamp it together...
From the research I've done, you just pull the engine off the unit, drain all the fluids, turn it upside down on a bench, and unbolt the crankcase off the bottom.
You don't have to disassemble the whole engine.
Yep not much to the job... The one I did he had replaced with a new gasket it blew out in short order. Its been on the RTV for about 5/6 years no leaks... If I where to use a gasket I would bond it so it does not slip out again... I assembled it with no gasket are sealer I still had crankshaft end play so went with RTV... Ultra grey permatex...
What part of NC are you in?
I did two tours at Cherry Point and had civilian friends in the Clinton, Kinston, and Wilmington areas.
Nice country.
I've always said if I ever decided to leave Nebraska for whatever reason, I'd flip a coin between North Carolina and New Mexico.
I like the people in North Carolina and the climate in New Mexico.
