Update on engine problems from down below
I finally fixed it. Drained the oil out of
the power steering system and put the
correct oil in it and changed the ignition
switch and now it runs like it is supposed
to. Thanks to all of y'all that gave me
some good advice I was pulling my hair out
on this one
Did you add a lot of fluid to the steering system or change the oil? If not it seems odd that it would suddenly start having issues. For most power steering systems if you have a light weight fluid in them like hydraulic or PS fluid or auto trans fluid they work quite reliably until a leak develops and they get low on fluid. Intermittent connections in an ignition switch can also cause a person plenty of grief. Glad you solved your issue and thanks for giving the follow up. Here is a link to the post that describes the issues you were having.
Original post on subject
