Previously I was having a real hard time getting the brake assembly off the right side of my 930. Turns out someone _welded_ a washer onto the shaft to hold the brake in place. Got out an angle grinder and a dremel w/ a cutoff wheel and was able to get it off and cleaned up with only minimal damage. Best I can figure, they welded that washer on because the disk's teeth were totally worn out and they decided this was a better option than buying a new one... Tractor also came from the Mississippi flood plain, so no such thing as a hill, brakes are nearly worthless when you're driving a 10k tractor + implement at 5mph, pop the clutch and it comes right to a stop anyway.
So I got the rest of the assembly off, up to the most inner brake... which was welded... Not a washer this time, the actual brake was welded to the shaft.
Took me nearly three weeks and a handful of bits to get the disk off. No I've got about a 1/2" thick ring welded to the shaft. My issue is I no longer have a tool capable of getting into there and cleaning it up. The cut off wheel won't fit into the housing at all. The dremel is too big, bought one of those attachments that lets ya have the dremel body in one spot and then the dremel bits about three feet off. But now even that's too large to get in cause of the angle of attack.
I'm thinking I gotta pull the shaft out to finish cleaning it up. Wondering how big of a job that is and if I need to order some parts, like gaskets to replace the surely old and worthless parts in there already. Anyone know what I'm about to be getting myself into here? I found a guy on Youtube he mentions he did this, but only in passing, never found a video of him actually pulling the brake housing off and the shaft out.
