Update Re: Jubilee three point hydraulics
Sawburner
Ok so I tested the pump pressure and I get 500 pounds. I tested it by blocking off the pressure tube where it comes up out of the center section. Took the pump apart and one side plate had some light scuffing the other side looked good. What are my options? I can see as TheOldHokie said that a new vane will fix it. Thanks Mark
Previous discussion
(quoted from post at 11:21:47 09/09/20) I can see as TheOldHokie said that a new vane will fix it. It should say NOT fix it.
Ehat i said was a new vane and rotor MAY fix it depending on how bad the wear is. You will have to evaluate that yourself.
TOH
OK. I misunderstood sorry. I see somebody dressed the side plates and replaced the rotor and that worked for them. I think i will dress my side plates and see how that goes. Then decide after that to buy a rotor. Mark
