update S/A rear end
glendora boy
up date bolts loose on outer rim going after new as they are cut in half any ideas to fix hole in center rim they are reamed out thanks again GB
going to try welding do you know bolt pattern looks like 19 3/4 center of hole also do the new bolts need to be square? thanks
Using grade 8 is a good idea with heavy nuts. The only issue with Hex bolts is the need to hold them on the opposite side. Not an issue in general, but since it is not a show tractor it matters little. Jim
