Updated Ford 532 injector pump question please help
Jim 777
Starts to run rough after about 20 minutes.
On injector pump where banjo nut enters pump, fitting spins at the two hole plate. is that okay? Also when I removed the two bolt plate, I found what looks like sawdust in there. how should I clean that out and is there a filter on the pump? If so where is it located.
Thanks have a great day.
The return valve should not turn.. you can epoxy it..
As far as the saw dust goes, I NEVER heard of such a problem..
There is a filter inside the pump. Its under the inlet nut..
Remove the big nut and gasket.. remove the big spring.
HOLD DOWN the guts w/ a small screwdriver and using a pick, pry the plastic filter out.
Blow it off and reinstall.
IF the guts come out when you pry the filter.. your in trouble.. HOLD THEM DOWN..
(quoted from post at 05:30:00 08/31/16) The return valve should not turn.. you can epoxy it..
Got the filter clean just didn't know there was another Inlet line. sprayed out all the powder dust and it is running again. Maine Filter was clogged with a bunch also. Do you think it could be sucking air at the banjo nut mounting?
Thanks Again.
