Upgrading / replacing my case 930 Hydraulics
My pump quit last spring and I haven't been able to make her chooch since. At this point I'm thinking I'd be better off putting a pto pump on and creating a whole new hydraulic system. A buddy of mine had a pto extension that had a gear on it so he could run a gear driven pump off of his pto and use the pto at the same time.
I'm thinking about doing 4 remotes, I have a ez - on loader that would be nice if I didn't need to disconnect every time I needed 2 remotes. So I don't know much about hyraulics what kind of advice can you guys give me? Should I build a open or closed system? I don't want to spend of fortune on this but I want dependable hydraulics.
Its a 930 ck orange road fenders. The local used tractor parts place wants $600 for a used pump with no guarantees on it working / dying. I've never personally liked the 930 setup because the pump and remotes and together and to my knowledge its not really possible to add remotes... or is it? I'd like to add a least 1 more remote for a grapple.
(quoted from post at 11:51:20 03/29/17)
First off 930 Comfort Kind with orange ROUND fenders, sorry for the typos it won't let me edit.
And second the used parts place will refund me if the pump does not work at all after installation but if it dies a week later its my problem. More importantly than that I was told that as long as the pump moved oil it would be considered working so if it had very low flow or pressure but was still working then no refund.
Check with Gotvald Imp, they are going to check, but think they have one and it would be in the $300-350
range if they do. Number is 320 355 2500..
