US Tractor model 10 A
Marlin Fabos
I just bought a US tractor Corp model 10 A crawler dozer with a fold down ripper on the front of the blad . Also has a metal curved canopy on it. I couldn't see it going to the scrap yard .It was just too cool looking so i got it for 500.00 The engine that was with it is a four cylinder Flathead with the distributor mounted in between the two middle cylinders Has a brass tag with Caterpillar an model number on it .But caterpillar says they have no record of this anyone with info and or manuals on this would be nice. Year??
Think they were bought out by Case in the late 50's and had Continental flat head gas engines. Guy down
the road a couple of miles used to have one. He passed away and I don't know where it wound up. It needed
an engine overhaul and reassembly when I last saw it about 6 years ago now.
Case bought out American Tractor Corporation, ATC/ Terratrac from the Rojtman family. My first thought was the small airborne style dozer made to military specs similar to the little Clarks.
Search for USTRAC dozer and some good links come up including several from YT in passed posts.
US Trac is the direct descendant of the WWII Clark Airborne tractor (and the "father" of the ATC line, and therefore "granddad" of the Case crawlers) having been made from left over Clark parts at war's end, with the exception of a change from the Clark Waukesha engine (IXB?) to a Continental F124 industrial, blade lift cylinder changes, hood configuration, and cylinder mounting tower access hole shape. There are probably a number of other subtle changes. I have parts lists (circa 1951?) which cross reference Clark/US Trac parts, with higher prices usually being listed for the Clark parts. A gentleman (county historian) recounted his memories of working in establishing the US Trac plant in Warren OH during his college breaks in the late '40s early '50s. At some point around the ATC buyout he said the building was sold to Packard Electric for wire production and he helped load rail gondolas with much US Trac property, including parts in process, machining equipment, spare parts, engines, etc., (for scrap) as Packard wanted a "broom clean" facility.
I have seen remains of what appeared to be 1 factory made loader version, and 1 angle blade version of the basic 10A; both are listed as "upcoming improvements" in my literature. Also the brochure I have specs the Continental engine, but the publicity photo on the leaflet is clearly of the Waukesha.
It is an interesting piece of history, and spins back even further to Federated Machine and Welding, a Cleveland company that developed machines and techniques for welding tank armor for the government.
I have never found any link to Caterpillar in my several years of research on this company; however the engine was used in numerous forklifts over the years and your's MAY be a CAT transplant.
Machine s/n should be on a brass tag forward of the base of the shift tower (all I've seen are 4 digit with 50 or 51 as the first 2 digits), early ones with Clark blades will have a large brass plate on the back of the blade stating LaPlante-Choate, with some other info. There should also be a tag on the reverser case cover with clutch adjusting instructions.
I have heard of, but never seen, a machine manual-I use the Clark CA-1 manual for all but the engine and a Continental F industrial series manual for the engine, not perfect, but adequate.
Hi, would you have any info for the clutch package? The ones built after the war had a different clutch setup than the Military models. Have a Model 10A Serial 05481, 1946 year? thanks.
Welcome to the forums.
smallercrawler's profile shows it has been almost 4 years since he last posted, at least using that handle, so you might not get an answer from him.
Ok, thanks. Do you know of any other source for info on these tractors? The Owner has a manual for the Military ones but the clutch package in his is completely different. The clutch is locked up and we can't figure out how to adjust it or even how to remove it? Thanks for the info.
I will say you are not dealing with a very common unit so answers will be slow and few. the only source I would have for info is web searching which is what I am guessing you are doing. I did find something on one site about those having a lever operated two disc, over-center clutch for forward and reverse. Is that what you are dealing with?
You posted "The clutch is locked up and we can't figure out how to adjust it or even how to remove it?" Remember we can't see it at all. The more details and pictures you can provide the better chance someone may have seen similar used and be able to offer ideas.
I believe that is the clutch. Two clutch packages at opposite ends of a common shaft. Front will rotate, Rear, is locked tight. It seems like something has moved out of position but not sure what to look for or where to look. I'll get some pictures. Thanks
Here are some photos. Hope they help. In the photo tagged: Clutch box looking rearward, that is the clutch pack that is locked up. Right below the splined shaft going into the gear box. Front clutch will rotate, transmision will rotate, tracks will rotate but clutch pack refuses to move. Thanks for any assistance or information you can provide.
