Using 6V lamps on a 12v conversion
I have a model 641 Ford tractor. I hear there is a way to use my old 6volt head lamps by installing a ballister resister to step down the voltage and then I can use the original lampss. Has anyone had any experience doing this? Where did you get the electrical part to do it?
(quoted from post at 12:01:29 04/15/09) I have a model 641 Ford tractor. I hear there is a way to use my old 6volt head lamps by installing a ballister resister to step down the voltage and then I can use the original lampss. Has anyone had any experience doing this? Where did you get the electrical part to do it?
Wire them in series instead of parallel.
The only problem will be if one goes out, both go out.
Peter.......while you can wire yer 6-volt headlites in series like old XMAS lites, WHY??? Don't be so fuggin cheap, buy NEW 12v 55-watt BRITE LITES 'stedda' using wimpy 6v 35w orange glows and see where yer plowing. New 12v headlites are cheaper'n 12-to-6v converting resistor ennyways. Take yer old 6v lite in to parts store and tell the clerk you want the 12v lite, that is what clerks are for. 12v headlites is one of the good reasons to convert to 12v. .......Dell, a 12v advocate for the right reason
Yes it can be done that way but why when the 12 volts ones are brighter and work better. If you hook them up as Dunk says when one blows out you loose them both. You can put in a ballast resister part # VR-1 but again why not do it with 12 volt bulbs and have it done so you will not have extra parts to worry about going bad
I did like Dunk says. Converted a CA Allis to 12V before I knew why it wouldn't start on 6V. I wired the 6V sealed beam headlights in series. Been that way for 10 years+ now.
Yes this can be done but it is not cost effective due to the cost of the high power rated voltage dropping resistor needed. Buy new 12V lamps or leave it 6V.
Dean
I agree with the others.. using a ballast resistor in series with the lamps is just a pitiful idea.. slightly less pitiful is wireing the lamps in series.
easiest is to buy 12v lamps.. however.. If I was 100% stuck on using the 6v lamps.. I'd wire them in series before I'd stick a big honkin power resistor in line with them that I could cook eggs on while running the lmaps.. etc.
soundguy
