using heater on trans pan ok?
ssickel
I have one of the magnetic block heaters. I have been using it on the hyd fluid on my 2N. Really helps with the 3pt warming up faster. Am I causing any harm to the system doing this? I am thinking of buying another so I can put one on both pans. Thanks Scott
You can even buy flexible silicone rubber heater pads with self-stickum for attaching them to oil pans or sumps.
<img src = "http://www.padheaters.com/resources/padheater_models.gif">
Omega Engineering sells flexible heaters.
http://www.omega.com/heaters/hsc.html
I found some 50W ones surplus some years ago. I wire 2 in series so they make more gentle heat and over more area. 2 - 50W units in series draws half the current through both so each makes 1/4 the power, or 25W total for the 2. I got a couple of strong magnets from Radio Shack to hold the heaters on the block or pan with some fiberglass insulation over them. Be careful with magnets and high temps - if you reach the Curie point for the magnet it will drop off and the heater could start a fire.
I use them mostly as "dew chasers" - also on my cast iron power tools - we have 5F right now but New England can warm up quickly and then everything gets condensation and rusts. I put these on when we get the damp warm-up and it is just enough to kill the sweating.
One manufacturer is the Kats engine heater outfit.
I don't know where you're at, but up here in the COLD north country pretty much every auto part store/NAPA is a dealer for them.
<img src = "http://www.fivestarmanufacturing.com/getfile/c6bdb220-e294-4a3d-a90c-7cab222fe879/silicone-pad-heater.aspx">
Kats Silicone Pad Heaters
* Oil and acid resistant, pliable.
* Use as oil pan or transmission pan heater.
* Available from 25 watts to 1200 watts.
* Easy to install, as it requires little mechanical ability.
* Universal Application
Kats
