VA Case wiring mounting for Lights
grampsh1
I am currently re assembling a 1946 VA after painting and wiring the
lights When I got this tractor 25 years ago only one light assembly
mounted at outer edge of floor board brake side and no wiring light
switch had a piece about 2” long attached to switch so wondering if
someone could start me in right direction on route of wiring from
switch to lights have added a second light on clutch side also a rear
lght on bracket below seat how was the wiring fastened to the torque
tube to get from inside dash from switch to floor boards Any
suggestions or help greatly appreciated
Paul
Seems like the wire ran down the steering column then under the footboards/panels. I think mine were in a fabric covering with some clips at the bottom of the steering housing and back of the footboards/panels. Been a long while ago I did my VAC so memory not so good with out going out to the shed. gobble
