VAC Case Light Switch
I noticed many vendors of the light switch for the Case VAC indicate their switch is for the VACs with serial number of 5060679 or earlier. My VAC is 5151692. Does anyone know how the light switch for that later tractor was different from the earlier version?
It depends if it has a cut out relay or voltage regulator on the 6 volt system. The cut out relay has to go through the light switch as part of the charging system for rate of charge.
Bruce .... actually, I think yours is a 3-position switch ..... all the way in (position one) is "controlled" (lesser) charge rate where the current (Field I think) feeds through the resistor to ground.
