VAC Fan Belt
LorenTN
I am restoring a 1948 VAC. Have been trying to find a fan belt. All three pulleys match,crankshaft, fan ,and generator, and need a 3/4" top width belt 43" long. Have tried all automotive chain stores also a couple different Industrial belt stores in Knoxville TN , no luck. All I can find are 5/8" ,which I am afraid will "bottom out" and start slipping after a few hours use, or 7/8" which will ride too high on the pulleys. Is there a source where I might be able to find a new belt or a NOS for under $15.00? Any suggestios will be appreciated and thank you for the help. I would very much like to have the RIGHT belt but I could go with what I have as this tractor will probably only be used for show.
I've been getting mine from my local CaseIH dealer,it fits and even has CASE written on it.I think the last one I bought was about $23.I can post the number if you are interested. Nick
I have been using belt # 24443 or 24449 and have had good results. First 2 digits are width in 32nds, last three are length (44.3, 44.9). They are a little longer that what you are looking for but seem to work fine. That # is good for Goodyear, Gates or Dayco. Probably some others also. A 28457 is what most application charts call for and will work but like you said it rides up out of the pulleys a little. Should be a ditributor for any of them in Knoxville. You may have to pay over 15 though.
