VAC Valve cover needed ASAP
Obession
I ordered a VAC case valve cover and the vendor shipped the wrong gasket. I want to buy one locally and would like to have it by Friday. Who and where can I get one fast? What is the part number? I have a body shop waiting to blast and paint. Help!
Go to your local parts store and get some cork or cork-like gasket material and cut your own out. The one that I made works a lot better than the rubber/neoprene one from CaseIH.
Victor # VS 38250. Should be available through any NAPA store. Fel Pro # VS6907R. Will be rubber but would get you out of a bid. Should be available through most discount auto parts stores ( Advance, Autozone, etc.).
Permatex Right Stuff. I was a little skeptical at first, but have used for differentials, pto"s, diff brake half shafts, it works. Next time I need to drop an oil pan it will be my choice. Follow the directions and it works, haven"t leaked a drop in my uses. Not sure I would use for applications under high pressure, but for a valve cover should be fine. You can get it at almost any auto parts store.
CARQUEST was able to get me the Victor next day. I also got the pulley. Thanks Lee.
-FYI I am not apposed to making gaskets. I made quite a few for this tractor. It is a lot cheaper.
