Value of JD2355
kplind
Does any one have any idea what a 1991 JD 2355 would be worth? Here are a few more details: 3000hrs, Rear wheel weights, big after-market loader, after-market cab. I would consider the condition of the cab and tractor to be Fair at best.
Also if any one has any experience with these tractors in cold weather? I would be interested in knowing how it starts when temps are below zero.
A good one, you can't ask for better. If abused, a real headache.
If the coolant's anti corrosion inhibiter has expired. The engine sleeves will be pitted and ready to leak.
If anything other than a quality wet clutch compatible oil has been added to the trans/hydraulic system. The brakes, high/low shift, pto clutch/pto brake will be damaged.
Being a loader tractor the clutch maybe worn out.
Really doesn't matter about 0F temps. Any and every machine should be plugged in and pre-warmed at freezing temps. Even if it will hammer to life without pre-heating.
kplind,
55 series are some of the best tractors JD has built. I've not seen a 55 series with an aftermarket cab but most aftermarket cabs are noisy compared to a SGB. An open-station tractor as you described would bring $12K to $15K here in Texas. Look at Machine finder .com or Fastline for some prices.
