Value on wheels and tires?
Rick Kr
I finally have my Ford/NH3930 switched over to my R-4s.
I have the 9.5-24s and 14.9-28s with wheels to sell, but have
no idea where to start on price.
They are worn, but usable. One 14.9 was vulcanized since
I’ve owned the tractor for 17 years.
Thanks.
I just picked up 2- 14.9x28’s Goodyear that are worn, but not cracked or tore. They came off a FWA. $200. There are some 16.9x28 on rim, no centers, checked and weathered on CL. $460.
For me the tire in the first picture has zero value. Maybe you can find someone who can use the other tire and rims. Get $200 and put some/most in the collection plate on Sunday as you were very fortunate in my mind.
I dunno what the life span of a vulcanized tire should be I have one that was repaired just like that 40 years ago the tire should have been thrown away then it was rotten and well worn...
Some poor boy could use it, its not worthless...
Is that bolt circle 8 on 8"?
What size are the lug/studs on the tractor?
I would really like to put 14.9-28s on one of my tractors but need them 8 on 8" and for 3/4" studs. I need the complete package - rims, centers, tires, tubes.
(quoted from post at 04:32:04 10/20/20) Is that bolt circle 8 on 8"?
3930 will have the same 8x8 bolt pattern as the 3 cylinder 4000.
I sold a set of tires and wheels with centers from a 3930 back in the spring.
14.9-28's 9 years old with one having a 3" cut between the lugs from a broken glass bottle, cut was to the cords but not thru, they still had 80% thread, one rim was bent in at the bead but could be straighten with the tire off.
Sold them local for $700
Ultradog,
These are 8 on 8 with 3/4" studs (1 1/2" lugs). A lot of the mid size Fords and New Hollands use these.
Im in mid-Michigan.
Rick
