Russ from MN
- Location
- Bemidji MN
I am past due on the recommended valve clearance check on our 2001 JD 4600, and I know I have seen a simple procedure on here before. It's a 4-cylinder Yanmar diesel, and has always run great, and I want to keep it that way. I can turn the engine over with a socket and U-joint and long extension, but it's not easy, so I want to minimize turning it. there are no timing marks that I'm aware of, so I will just be going by rocker position for piston location. I have seen in the past a procedure where you stop the engine in a certain position, adjust 4 valves, then turn it, and adjust the other 4 valves, that's what I'm looking for. I tried googling it and don't see the procedure I'm looking for. I have adjusted valves on many different kinds of engines, so I'm familiar with the procedure, just want to minimize turning it. Thanks!
