Valve clearence
RSapp
Have a JD G. Replaced pistons with high compression pistons, new rings, valve job. Started it up, ran it for awhile (30 min).Started running rough. Checked valve clearence, had changed to about 1/4 in. reset them, fired it up, run it awile same thing. We did not get into cam or cam followers. Need some ideas. Thanks in advance
I doubt the camshaft is destroyed. Double check all bolts holding the rocker arm. Set valve clearance again. Are all valves acting the same?
Richard
rocker arm bolts are tight as this is what we originaly thought also. all valves have been reset several times with same results. any other ideas?
A possibility you'll want to check is the cam bearings. I'd back off the rocker arm assy, pull the top cover and see if there's any play there. May not be it, but worth a look. Mike
Pulled top cover but found no side to side play and very little foward or reverse on camshaft.cam followers and or cam? Or both ?
Thanks in advance. Rich
