Bob in Tennessee
My 8N has suffered from a coolant leakage for some time because of a broken block and it has degraded my valve seat chamber to the point that the seat has separated from the block. Is this a repairable
situation considering the cost of a used block and parts and machine work would be more than the value of the tractor itself? Is is possible to re-seat a seat into this block in the current condition?
What would you guys do? It is a front mount 1949 8N 12Volt conversion with front mount EI. Ran great until this issue even with the broken block. The corner of the block broke when I drilled out and re-tapped
a head bolt after the original stud bolt broke off during removal. Never could get it to close properly. Obviously the engine that came with the tractor when I bought it thirty years ago was from a 2N.
