valve stem replacement
Tomfuller
Hi! I have a tire on my van that keeps going flat and I can see it is leaking around the valve stem. Can I just replace the valve stem or is there a tube inside?
(quoted from post at 08:29:18 06/28/16) Hi! I have a tire on my van that keeps going flat and I can see it is leaking around the valve stem. Can I just replace the valve stem or is there a tube inside?
Well, to replace the valve stem, you're going to have to break the bead on that side. So if there is a tube in there you will find out then.
Uh.. no.. he doesn't have to break the bead if it is a rubber valve stem.
the rubber ones can be pulled out, and a new one inserted with a pipe style insertion tool.
(quoted from post at 10:35:28 06/28/16) Uh.. no.. he doesn't have to break the bead if it is a rubber valve stem.
Ok, thanks. Just never seen one inserted from the outside. I would like to see how it works.
