Valve train anomoly
james Hurt
Coming to the well of knowledge again!
O.K. I pulled off the valve cover to clean it out and discovered one of five studs/bolts holding down the rocker arm shaft was broken. I extracted and replaced it without much problem and hand cleaned the visible moving parts. I torqued all bolts per spec and removed spark plugs to spin the engine to check for oil flow and proper movement in the valve train. One of the eight rockers (on the opposite end of the motor as the broken bolt) was stuck in the full open position. Since that should have caused a permanent miss in the engine and since the engine ran strong (before my brilliant work) the malfunction must have occured due to my error. Any ideas on cause and what series of checks could I run?
(a) test the spring for proper tension?, (b) check the lifter rod for straightness? (c) attempt to collapse the lifter from above?
Tractor 1967 Case Model 540. 159CI.
You probably got the pushrod out of the lifter. Remove the rocker shaft and make sure they all move freely with no "slop" on the shaft. Be sure to check that the pushrod is not bent, and that all of them are properly seated in the lifters, then re-install it. You might want to turn the motor over a couple times before replacing the valve cover, just to be sure everything is okay.
Good Luck and God Bless,
Tommy
The adjustments and changes you made probably pushed the valve a few thousandths farther into the guide. It is just stuck open. or as the other responder indicates you got the pushrod into the hole crooked, and it just needs to be seated to work. There is no collapsing, the lifters (to my knowledge) are solid and will need to be adjusted to spec at the rocker. JimN
